S/D and bigger cam
notched88
Does anyone have an idea on how speed density and fords F303 cam might do together? i just got the car a couple days ago and had no idea there an alternative to a maf, guess i ended up getting it. Any information would be appreciated thanks.
well the F cam is pretty big and because there is no maf the car will surge unless you bump the idle up to about 1200. the car will run rich because the map sensor will think the car is under load and will dump more fuel in, it can be done if gas mileage is not an issue
