?'s On Car
  • Thread starter Thread starter xc_myers_06
  • Start date Start date Mar 12, 2006
xc_myers_06
64
Nebraska
Mar 12, 2006
  • Mar 12, 2006
My car makes a whine sound when i drive around what would that be? (i don't got no turbo/super charger)
xc_myers_06
64
Nebraska
Mar 12, 2006
  • Mar 12, 2006
I also have a ? on my keyless entry. I am pretty sure i have the stock keyless entry but i also have an alarm installed, but i dunno if either of them work or anything because i don't have the key fobs. My lights on my rear-view mirror come on when i open the door. i looked in the trunk but didn't check all the way down beneath the plastic cover but there were wires running through there? so if i bought a key fob do u think it would connect?
Guero
2,148
Mar 12, 2006
  • Mar 12, 2006
you have a stereo system? maybe your power steering?
xc_myers_06
64
Nebraska
Mar 12, 2006
  • Mar 12, 2006
I just replaced the P/S pump and all new Rack and Pinion though and i have a stock Mach460 Sound System
HISSIN50
34
129
Mar 12, 2006
  • Mar 12, 2006
Try to provide more info. Like does it whine while turning, only going straight. Only in gear, only at some given RPM. Etc.
Remember, all that stuff is in your sub-conscience but we dont have a clue from our little keyboards.
For Keyless, most installers seem to tap into the lock wiring in the driver side rocker panel. If you get down there and see the lock wires tapped into (with a fuse tap or a soldered Tee), that suggests factory keyless. If you see that two wires were cut and legs of wiring run from each cut wire, that suggests no factory keyless or a retard installer. Your dome light thing suggests keyless to me.
Good luck.
xc_myers_06
64
Nebraska
Mar 12, 2006
  • Mar 12, 2006
Hey well it whines while it is just starting up and then whenever i go and i drive only it town so i don't know if it is cold starts or not. i don't drive far. but it whines pretty loudly.
I will check into the keyless.
Also i have one more issue! (probably got tons more) but this issue is when i let go of the throttle the car like jerks a lil and seems to slow down right after lettin go of the throttle but lasts only for a lil bit right after letting go of the gas. anyone got a clue there?
SN95StangMan
1,292
Lynwood, CA
Mar 12, 2006
  • Mar 12, 2006
my alternator gives me a little bit of a whine/howl when driving around town.
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Mar 13, 2006
  • Mar 13, 2006
When I stand in back of my car when it is running I hear a loud whine. It sounds like its part of the exhaust but I know it's not. Maybe its the fuel pump? I don't know.
donjohn
1,757
Irvine - Southern California
Mar 13, 2006
  • Mar 13, 2006
several whines man... you need to narrow down the location
some of the most common are:
-fuel pump (sounds like it's coming from underneath the rear seat)
-smog pump (under the alternator) or alt
-squeaky pulley - try spraying some wd40 on different pullies to see if it's an easy fix
-you might just have a loose belt
xc_myers_06
64
Nebraska
Mar 13, 2006
#10
  • Mar 13, 2006
  • #10
I will check it out then, but i also gotta a question on my throttle problem. I hit the gas and it shifts nice and good but then when i am driving around and i let off the gas the car seems to slow down for a second like with a lil jerk. i dunno if that is normal or not but it is a little bit of a different feeling. so anywayz it is a lil tug forwards everytime you let off the gas. Also i think that if it isn't the squeaky pulley then it could be the fuel prob. cuz i have lack of gas it seems like that gets to the engine which causes me to stall at stop lights on cold starts but it could also be the IAC (from earlier thread with help of HISSIN)
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Friday at 12:37 PM
2000xp8
