s-trim or sc-trim?
sc-trim runs about 5-6#'s of boost while the s-trim runs about 8-10#'s of boost. They also have slightly different impeller efficiencies but I don't know the exact difference in the numbers.
What he said. Basically, they can both run the same amount of boost, but you will have to spin the SC-Trim a lot faster to do so. If your planning on running more than like 10lbs of boost, i would just go with the S-trim, they can be found cheap on corral.net.
Ditto, go with the s-trim. The SC-trim is the base kit, and usually makes about 6psi. The S-trim in the high output kit and makes around 9psi. There are two different s-trims however. There is the standard s-trim, or v-1 compressor, which is the noisy one. Then there is the SQ-trim, v-2 compressor, which is the quiet version of the s-trim. A lot of times, folks get the SC-trim and SQ-trim mixed up.
The SC kit lacks a few hundred bucks in parts, so as said above, get the S.
And if you have big plans for the car in the future, get the HD S head unit, it's the only one that can be upgraded to a T trim.
