So I have someone that will trade a complete pdp single turbo setup with very low miles for my S-trim setup. What would you do? I would think supercharger would be better more for a daily driver and since I hear so much about how hard it is to tune a turbo stang and how picky they are with different weather and such. Is there such a thing as turboed fox for a reliable daily driver even on low boost? (5-7psi or whatnot). What's the pros and cons of both? Should I be so worried about the tune as I am?
And could someone tell me how a turbo car is tuned without an fmu? Since a blower gains boost per rpm so it can have the same "fuel curve" every time. But a turbo can say start to build boost around 4,000rpm on level ground giving 1/4 throttle or start to build boost at 2,000rpm at 1/4 throttle towing a trailer since a load is being put on (all just an example). How does the computer know when it's building boost so it can richen it up and increase or decrease the timing curve properly?? I understand you can tune it for WOT since it will have max boost at a certain rpm anyway and stay like that but what about under WOT. I would think some kind of boost controlled fuel enricher (yes yes I know that's a fmu but everyone talks bad about them) would be the best bet but I haven't seen anyone really using a system with a map sensor or whatnot to do that. Any info or enlightenment on this would be great, Thanks! Sean
and how reliable they can be.
