I guess you see that Thumper added the rest of the equation - you can run about as much compression as you like if you retard the timing enough. But if you want to run a reasonable amount of timing, something around 11:1 is likely to be where you'll start running into the limit. It also depends on geography - gasoline formulations are not the same every where in the country; and it varies seasonally - the warmer weather will be likely to cause detonation where it wouldn't detonate in the dead of winter; gasoline formulations are different seasonally too. It's those kinds of differences that allow for why some folks get away with a higher number than others. Quench also has a big impact on detonation - another potential variable from engine to engine.
