  • 1994 - 1995 Specific Tech
Saleen decal kit?
  • Thread starter Thread starter slayerripkdc
  • Start date Start date Sep 20, 2006
slayerripkdc
1,341
brewster ny
Sep 20, 2006
  • Sep 20, 2006
any of you guys have any expeierence with installing the saleen decal kit???? I just order the sallen decal kit and was wondering if you guys have any advice on installing them because i never did this before. Also is there room for mistakes?????? Like if i mess up can i take em off and adjust them again????
saleenadam
36
  • Sep 23, 2006
I installed the decals on my GT about 7 years ago so I don't remember much except that it was not that easy, but I bought them off of somebody so not sure if Saleen sends instructions when you order from them. When we did it we used a lot of Windex on the paint and for the windshield sticker so that the decals could be moved around instead of just hoping that we got them in the exact position on the first try. Just get somebody to help eyeball them with you and see when they look straight or I guess you could measure to be precise, and use something like Windex underneath and once they are straight push all the bubbles out. Once they are stuck on i'm doubtful that they can be pulled off and put back.
RIO5.0
6,892
N.H.
Sep 24, 2006
  • Sep 24, 2006
I installed the side stripes before...I think??? they had some reference dim's in the package or something, was along time ago though.
I would use bug/tar remover to clean the work area, then like Isopropyl Alcohol aftrewards to prep the it..this will remove and wax and grime...Little nerds stuck on the paint will show through the decal, and trap air around them...Not good...Been there had that...
I used masking tape to kinda set my points top/bottom and you can even run the lenght of the angle down the door then lay your decal edge against the tape ..you can measure and mark accordingly with tape..
Leave an 1/2" extra to wrap around the door edges to..you kinda roll it around the edges for a clean look.
I used a spray bottle with a tsp of dish detergent in it....spray the area with plenty of that...you can slide/reposition the mother quite awhile with that..if you have to peel it up and reposition it, you have time with that water/soap solution..just wet the area down again...KEEP THE ENTIRE AREA PLENTY WET...dry spots will kill you..
I used a soft damp cloth to get the major water off and then work from the center out...air bubbles suck to get out as you goota push em to an edge...
PLENTY OF SOLUTION...WORK GENTLY FROM THE CENTER OUT.you dont want to stretch em..Its almost a one shot deal cause after you kinda seat it and push the air/water out and she's there..Pull it up after you did that step and it'll stretch the decal and it wont quite seat right again...
Don't worry about them sticking cause of the Windex or solution you use..once you push them down solid..they stick like a mofo and ain't coming off....Take your time and you'll be fine...dry run the fit a fine times...tag em with small pcs of tape to hold em and stand back and look...Good luck..
86 saleen grounds affect kit
  • Bwaldo02
  • Sep 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 2, 2025
2000xp8
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
