I'd be weary of having to drill 3 holes into my dash. But heres some info on the install from a Saleen blower install manual:
Have to make a template for the pod, so that it is centered just right for the 3 holes you have to drill out:
A template someone made when doing the install:
Pic from that guys install:
Some of the directions that guy posted:
- (Gauge Pod) Remove the dash bezel and instrument cluster. GLUE the #10 nuts to the washers. Drill (3) holes in your dash centered above your A/C outlets.
- Make sure and check your directions for the TEMPLATE and wiring diagram. It helps if you have a son with long arms and patience.
- Drill a hole in the firewall for the wires to pass through. Splice your wires with the connectors provided.
These are not my instructions, like I said this is not something I would do. But I remember seeing these directions when installing my Saleen blower - in the online manual I found that someone posted up.
Hope that helps...
