Roush Saleen with Nitrous? Should I?
129saleen
124
Houston, TX
HELP ME PLEASE READ!!!!!! ? about SII with Nitrous
Can a SII SC handle 430rwhp....Right now i have 355rwhp and am planning on adding a 75 shot wet kit tommorow....Is my motor and sc going to be able to handle this or is this a disaster waiting to happen???? I have been told by some car shops that my car can handle it but some say it may not be able to... I have 75mm TB, 90mm LMAF, 66mm SC Pulley, 42lb.Injectors, LT's, o/r H, with an SCT chip. Also if it does work fine will I have to re-tune it or no?
Please hurry and answer this other wise its going on.... :rolleyes:
Thanks for any help....
If you haven’t researched it thoroughly by now, maybe you should not pull the trigger right this moment.
I remember some years ago, TMJ01 Tom did a dry test 25 shot (un-metered) on a Series II and gained incredible HP and torque (way more than 25). I don’t recall the actual numbers but I think torque was up substantially over 500 to the wheels!
Will the stock block even handle another 75HP and likely greater torque?
If you value your car i wouldn't do it. Unless of course you want to HAVE to build a better shortblock.
A 75 shot will act like a supercooler because of the supercharger, and you will likely get way more than 75 hp.
