Starting work on the brakes on the 68 and I was wondering if it would hurt anything to sandblast the entire rotors, brake surface and all?
Would the sandblasting leave an uneven surface, similar to a warped rotor or would it be fine if I took it easy? The rotors have quite a bit of surface rust from sitting for so long.
I will be installing all new bearings so would leave the old races in place until done but would probably also try to seal the inner areas off as much as possible also. Thanks.
David.
David.
