Okay ... I really, really hate declaring a victory early when I'm not 100% sure I've got the upper hand on things, but ... if this hasn't done the trick, then I'm sure that I'm on the right track.
New IAC (warranty swap) and new TFI module are in. Timing's set to 12* with spout out, running 92 octane (at $2.79 a gallon x 10 gallons, that's only $2 more than I'd normally pay. Why not?), and the cone filter's back on. Going to let the setup "settle in" for a couple of days to see if anything arises.
Drove around for an hour, re-started a few times here and there for good measure, stopped at almost every light I could just to test the idle. Idle is rock solid and silky smooth. Motor roars right up the RPM's without a single ping, knock, rattle, burp, hiccup, fart, stutter, or other obscene bodily function. No backfiring, no power loss ... YET. Again, I'm waiting a couple of days before I even dare to claim that this could very well be the miracle solution to my misery.
Totally irrelevant but amusing side-note: My distributor is GAY. No, seriously. It says so right on the label. Some series of E7-something numbers, then "with module," and right underneath in big huge bold letters ... GAY! No wonder the thing's been acting a bit queer.
Oh, I crack myself up. Anyway...
Distributor shaft still doesn't have any wobble to it, and there's still a proper amount of magnetic resistance when you spin it by hand. No arc-over spots, unusual burn marks, or evidence of other suspicious activity to be found. Getting the dist' back in there was a tad trickier for some reason this time, as it took me four stabs to get the bugger to stop going back in one tooth off. When I finally got the rotor aimed back to cylinder #1, I just re-adjusted the dist' with my old marks, cranked her up, and VOILA! Sitting perfectly at 10* again! (That is, of course, 'till I decided to be greedy and go for 12* ... heh).
I will pull codes again in a couple of days to see if I'm still running lean. If nothing new/exciting arises, then this could very well be it. If not ... umm ... welllllll...
Oh, I crack myself up. Anyway...Distributor shaft still doesn't have any wobble to it, and there's still a proper amount of magnetic resistance when you spin it by hand. No arc-over spots, unusual burn marks, or evidence of other suspicious activity to be found. Getting the dist' back in there was a tad trickier for some reason this time, as it took me four stabs to get the bugger to stop going back in one tooth off. When I finally got the rotor aimed back to cylinder #1, I just re-adjusted the dist' with my old marks, cranked her up, and VOILA! Sitting perfectly at 10* again! (That is, of course, 'till I decided to be greedy and go for 12* ... heh).
