SBF crank snout diameter?
  • Thread starter Thread starter SoCalCruising
  • Start date Start date Sep 20, 2005
SoCalCruising
2,437
SoCal
Sep 20, 2005
  • Sep 20, 2005
I'm away from my garage, tools, crank, etc. Does anyone know the diameter of a 302 crank snout? Thanks!
10secgoal
2,801
San Diego
Sep 20, 2005
  • Sep 20, 2005
I don't know it should be, idealy. But most off by a few thousands anyways. And when you get a new dampner, they are small enough to take some meat out, so it fits the crank correctly.
SoCalCruising
2,437
SoCal
Sep 21, 2005
  • Sep 21, 2005
Answer: 1.375" on mine. I already (previously) had my damper honed to fit. This question had to do with how my crank gear was fitting and how I was planning to make a fixture to hone its ID, slightly. I was at work, was making the fixture and didn't have the dimension handy.
In your experience, how tight should the crank gear be? Or, how much force should be used to mount it? Thanks.
SoCalCruising
2,437
SoCal
Sep 21, 2005
  • Sep 21, 2005
Answer: very tight with 9-keyway sprocket like I'm using. I have learned that it should be heated and then pushed on with a proper sized tube of aluminum. Anyway, ya'll can ignore this thread now.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 22, 2005
  • Sep 22, 2005
Install with heat? Thats ounds too tight to me. The handful of smallblock Fords I've dealt with never needed heat to install or remove the crank timing gear. It should be a slip fit.
SoCalCruising
2,437
SoCal
Sep 22, 2005
  • Sep 22, 2005
Evidently, the 9-keyway model requires a tighter fit, according to Kato Engineering at the Corral. His advice is generally spot on.
65ShelbyClone
4,675
38
119
Sep 22, 2005
  • Sep 22, 2005
Yeah, Kato usually is; I've just never heard of having to do that before.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Fuel Damper, 2003 Mustang GT
  • bmmckl
  • Dec 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 19, 2025
bmmckl
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
