scanned codes
  • Thread starter Thread starter bobbyd
  • Start date Start date Jun 11, 2005
bobbyd
312
San Antonio/Los Angeles
Jun 11, 2005
  • Jun 11, 2005
i scanned codes today and did it without turning on the engine for a lil bit i did the KOEO and i got code 11 and code 12 what can I do fix code 12?
11
System OK
12
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 11, 2005
  • Jun 11, 2005
Code 12 -Idle Air Bypass motor not controlling idle properly (generally idle too low) - IAB dirty or not working. Take it off and clean it thoroughly with throttle body cleaner. Clean the electrical contacts with non flammable brake parts cleaner at the same time.
bobbyd
312
Jun 11, 2005
  • Jun 11, 2005
quick question what is the normal rpm at idle? 900-1000?
thankx i will do that my idle is at like 900
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 11, 2005
  • Jun 11, 2005
Normal idle is 650-725 RPM, warm engine, A/C off.
bobbyd
312
Jun 11, 2005
  • Jun 11, 2005
hey got another question for you when i turn on the car theres no check engine light at all
HISSIN50
34
129
Jun 12, 2005
  • Jun 12, 2005
check for a burned out bulb behind the CEL icon.
Good luck.
stang22
1,318
Washington, D.C.
Jun 12, 2005
  • Jun 12, 2005
Or no bulb at all...
Tim
HISSIN50
34
129
Jun 12, 2005
  • Jun 12, 2005
Tim
What deviant would remove the bulb?
Very good point Tim.
bobbyd
312
Jun 12, 2005
  • Jun 12, 2005
Good luck.
where exactly is this inside the car or under the hood haha im a newbie
bobbyd
312
Jun 12, 2005
#10
  • Jun 12, 2005
  • #10
basictly this is what happends when i put the key on the ignition the check engine lights is on as the airbag light blinking and when i turn on the car the check engine light is no longer on but the airbag keeps blinkin a code
HISSIN50
34
129
Jun 12, 2005
#11
  • Jun 12, 2005
  • #11
The CEL should illuminate for a second or two upon turning the key to the 'on' position (to let you know the idiot lights work). then they go out unless there is a serious code stored. If the lights come on with turning the key on, the bulb/circuit works.
To address you previous question, the bulbs are right behind the facia (which has the icon). remove the instrument cluster to access the bulb.
What is your airbag code?
Good luck.
bobbyd
312
Jun 12, 2005
#12
  • Jun 12, 2005
  • #12
Good luck.
ah aight gotcha. thankx for the info and clearing that out. the airbag code i think its 23 or 53 cant remember its been a while since i checked the code for that. and thanks for hte good luck
HISSIN50
34
129
Jun 12, 2005
#13
  • Jun 12, 2005
  • #13
You should be able to clear soft air bag codes, while I think you need to have someone clear more serious codes (true on 94+ cars at least).
bobbyd
312
Jun 12, 2005
#14
  • Jun 12, 2005
  • #14
yea i just ignored the airbag code now
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
