scanned codes
i scanned codes today and did it without turning on the engine for a lil bit i did the KOEO and i got code 11 and code 12 what can I do fix code 12?
11
System OK
12
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
Code 12 -Idle Air Bypass motor not controlling idle properly (generally idle too low) - IAB dirty or not working. Take it off and clean it thoroughly with throttle body cleaner. Clean the electrical contacts with non flammable brake parts cleaner at the same time.
quick question what is the normal rpm at idle? 900-1000?
thankx i will do that my idle is at like 900
The CEL should illuminate for a second or two upon turning the key to the 'on' position (to let you know the idiot lights work). then they go out unless there is a serious code stored. If the lights come on with turning the key on, the bulb/circuit works.
To address you previous question, the bulbs are right behind the facia (which has the icon). remove the instrument cluster to access the bulb.
What is your airbag code?
Good luck.
Good luck.
ah aight gotcha. thankx for the info and clearing that out. the airbag code i think its 23 or 53 cant remember its been a while since i checked the code for that. and thanks for hte good luck
You should be able to clear soft air bag codes, while I think you need to have someone clear more serious codes (true on 94+ cars at least).
