My front left tire was worn down to the threads on the outer corner (not the alignment), and now I'm hearing like a whirling/humming/grinding noise when im below 10mph and stopping or turning right. I JUST put a new tire on because I don't feel like having a blow out and killing myself. While it was on the lift it was checked out and the right wheel outer tie-rod had alot of slack in it. I'm changing that asap. But the grinding/humming noise would be the front wheel bearings correct? It made the same noise when my bro's truck's front bearings were shot. I'm putting on new control arms with new balljoints and control arm bushings(hoping to fix the left wheel wear) and new slotted rotors with new pads, bearings, and seals. How do I adjust the wheel bearings?
Spin the wheel and tighten the nut tight to seat the bearings and then let off how many turns? How does everybody do it?
