Got me some new seat belts, these are http://www.drakeautomotivegroup.com/Store/Product/SB-3P-BK-PBSB.aspx?wid=141
I've figured out how to put them in, but the OEM bolts do not fit the holes in the mounting tabs. The description says it reuses the OEM bolts, but they have a 1/2" shoulder on them. These have a 7/16" hole. After contacting Scott Drake I was told I can drill them out or use 7/16" bolts. Neither of which I find acceptable for a $209 "bolt in" part. I pressed further and was told all aftermarket belts are like this.
I'd like to know if anyone here has dealt with this issue, and if the hole size is true, is drilling them a size bigger acceptable? Or should I return them and look else where. If I return them, are there any belts you'd recommend that will fit without issue?
Thanks!
Thanks!
