This is my first post on this forum or any forum and I hope that this one challenges the community and also resolves the problem for me.
I have a 1997 GT SOHC with an automatic transmission
mad
with a stalling problem. Some background: I noticed that the car would idle a bid low and occasionally when I would shift gears the idle would drop really low and sometimes cause the car to stall out. With the addition of a cracked intake manifold that was leaking fluid into my 4th spark plug and causing major power loss. I have replaced the spark plugs, fuel filter, intake manifold with new upper and lower gaskets, and placed a used set of ignition coil packs recently (car ran fine since i out the coil packs in). Today after finishing the intake manifold job I started the car and everything was fine. I was able to let it warm up and take it for a short test drive. The car ran great. I drove home and park the car in order to inspect for leaks or what not... none found. I decided to take another test drive... the car started fine and idled fine in Park and Neutral... but when put in R, D, 1, or 2 the car just dies out.
When in Park or Neutral I can rev up the engine and no stalling or power loss. The engine light is not on and I have not been able to pull codes since i can't drive to Autozone. I checked the MAF sensor and its clean. I was thinking it may have something to do with IAC or Torque Converted from looking at other post. Please help me with this one. This is my daily driver. Thanks for any help.
