- Jun 21, 2004
- 172
- 0
- 0
Do you have a predator? What suspicions?Kilgore Trout said:Confirms my suspicions!
Predator > SCT
How you know it stopped working? did your car act all crazy? Is there anytyoe of warranty for those SCT 4 bank chips? i hope socrazystang05 said:ok my sct 4banks chip just stopped working so pissed only had it like a week
did u have to disconnect the battery when u first installed the chip??hotmustang331 said:It probably came loose at the computer output. When you try and fit it up in the original location i noticed that it would not fit...SO I just left it loose in there so as not to put the chip in a bind and break something. It dosent rattle and it cant go anywhere...0 problems with mine, and boy did it help low-mid range grunt....fliped the switch to 4 (stock) and my car felt like a dog, even at WOT....shut the car off going down the highway and put it back to 0 (93)...even #1 (87 octain) feels ALOT stronger than the stock program, and in reality there isnt much difference power wise between 87 and 93. Pull the computer back out and see if its loose.
Predator > SCT
Predator > SCT
UhadMEatGT said:Where do you install them and how hard is it to do?? That is the box with 4 settings in it right? Do they come with the settings in it to choose from?? Thanks!
Mr GT 02 said:did u have to disconnect the battery when u first installed the chip??
hotmustang331 said:Well you know what, I dont recal doing that. I simply MADE sure i didnt turn my key to the on or ACC position at anytime durring the install. The chip came with instructions, and I followed them to a T....took FOREVER getting the coputer port clean, took a knife and carefully pilled the coating of silicone or whatever it is off, then used the supplied scratch pad to sand the metal prongs down until you could see a hint of copper in the metal all over the prong...not just 1 spot, didnt want to take a chance LOL.
crazystang05 said:yea when i first installed the chip i discopnected the neg cable, i just got it to work again by removing it the neg battery cable for like 15 min then reataching it and it worked
