sct sf3
i was wondering if it is possible to use my tuner to change my speedo reading. like for instance make the speedo read lower than what the car is actually going? i know you can use it to make the speedo correct after installing gears but is it possible to use it to change it to where the speedo reads lower?
yes but deliberately doing it would be illegal.
its like turning back your odometer..the "slower" youre traveling the less ground you cover, therefore less mileage is put on the odometer.
unless i misinterpreted, i am done here.
