Give Me TP
If you have to buy a performance tune or tunes it should not cost a lot, since many SCT dealers are now offering them and competition keeps prices reasonable. I would be surprised if does not even allow you to adjust your stock tune, since both the Predator and Superchips tuners allow some user adjustments to your base factory tune. Also, consider a dyno tune from a shop using SCT software.
A Predator, when bought new or used, is set up with a generic performance tune common to all Predator tuners and the option to apply coarse adjustments to that performance tune or your stock tune. Like the XCal 2, a dealer or a dyno shop can write a custom tune or tunes for it.
no, you said it was locked to the ecu code and could only be used on another vehicle with the same ecu code, when in fact it is locked to the VIN and can be reused on up the three vehicles regarless of ecu code as long as it is unlocked from the original cars VIN. It also can not be used on another vehicle even with the same ecu code if it is not unlocked from the original VIN. The customer can unlock it from the vin by returning it to stock and unlocking it with the XTreme tune software.
) Plus my dyno tune ($215) came to $540 compared to $625 my friend paid at the same shop for his chip and dyno tune. I came out a little ahead (at this shop...others may be cheaper or more expensive).
