i have 2 questions which im sure will be easy for you guys. first wuts the best spot to seafoam the engine. and second what are the best shocks/struts for around $300. i was gonna go with the ebay tokico blues but they are on backorder thanks!
The KYB struts are pretty good, and comparable in price to the Tokicos. You can suck Seafoam in through the PCV line, or the line that goes to the vacuum tree.
ok im probably gonna go with kyb ive also haerd from others that they are good and mine are getting horrible so i need to act fast. as for the seafoam im not good with names so is there a diagram or pic you could show me just so i know wut hose it is and where to disconnect it to vacuum the seafoam. thanks for your help!
ok im probably gonna get the tokicos off ebay. now my question is, is it worth it to get the ones with springs for an extra $125? and also am i gonna need to get bushings or anything else for the install. i wont be doing this myself so i want to make sure i have everything when it comes time. here is a link to what i will be getting unless i get the ones with springs too, which i believe is still the same shock though. thanks http://cgi.ebay.com/ebaymotors/TOKI...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
could some show me a pic or diagram of what hose to use when vacuuming the seafoam into the engine. and if possible tell me the best method of doing it. thanks
ok now ive read that using the brake booster line is a lot easier but some say it only feeds 3 cylinders and others are telling me it feeds all. what is true?
