wazazzle said:"illwood" it states "When Added to Crankcase (Oil) Frees sticky lifters and rings, Increases R.P.M.'s vacuum and compression, Cleans dirty parts, Removes moisture, Cleans PCV valve systems, One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart)." http://www.seafoamsales.com/motorTuneUpTechGas.htm so yeah you can add it to oil, should work wonders for you.
darthcual said:On the subject of additives, I used some Barryman B12 in my gas tank (one can on a full tank) and it really freed up some hp by unclogging my injectors. I would recommend this stuff to anyone with high mileage engines. As for seafoam....Parts Store here i come!
Nice attitude. I meant to put O2 and cat safe.black8989 said:It say's o2 safe right on the can, try reading before posting.
just a word of wisdom, b12 chemtool does work well, but i wouldnt use it often. the main ingredient is tutolene(sp) which will give you very high combustion chamber temps, not to mention is will dry out your cylinders. not saying dont use it, but after you do you should run some 2cycle oil through the tank as well.The Shape said:I just put a can of the B12 in my tank this weekend because I have been having a bit of a rough idle and I am gonna see what this does for me. I have no codes and did a tune up recently so I am hoping for dirty injectors and that the chem-tool B12 will clear it up. I have also been strongly considering doing a seafoam treatment.
Do you mean toluene? Which happens to be found in larger quantities in gasoline.wildstang87 said:just a word of wisdom, b12 chemtool does work well, but i wouldnt use it often. the main ingredient is tutolene(sp) which will give you very high combustion chamber temps, not to mention is will dry out your cylinders. not saying dont use it, but after you do you should run some 2cycle oil through the tank as well.
Hissin50 has helped pretty much everybody on this site (especially me) a lot. Try showing some more respect.
