Seafoam is teh *****!
  • Thread starter Thread starter MidnightGT
  • Start date Start date Jul 6, 2005
  • 9
  • 10
  • 11
  • 12
  • 13
  • 42
First Prev 11 of 42 Next Last
ponysarepretty
578
#201
  • Oct 15, 2005
  • #201
I don't think the ne with the red hoses is the PCV... is it? It seems to go into the fuel lines, at least on my car, I pulled one of the hoses that comes out of the passenger valve cover and goes int othe upper plenum... but then again mines an 01 and i think the yhanged it sometime between then.
ponysarepretty
578
#202
  • Oct 15, 2005
  • #202
On hindsight, if you should get suction from either valve, however you have to use a straw with the video method, however both go into the upper plenum, so I think its basically the same thing.
Am I right or was my car smoking for no reason?
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 15, 2005
#203
  • Oct 15, 2005
  • #203
You are right They both feed into the upper intake, so it still got into the engine. You should be able to put it in any vacuum line that leads to the intake. And NO, the one with the red hoses coming off of it is NOT a PCV valve.
Stang01GT
138
New Jersey
Oct 15, 2005
#204
  • Oct 15, 2005
  • #204
ok i actually put the seafoam directly into the vacuum line that goes into the valve cover not the plenum. I really hope i didnt do any damage, im gonna try it again tom the right way, anyone know if i cuda done any damage to my engine putting seafoam into the tube that goes dir into the valve cover
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 16, 2005
#205
  • Oct 16, 2005
  • #205
I haven't noticed any damage, and I did it that way the first 2 times.
ocbaud
239
Midwest City, Oklahoma
Oct 16, 2005
#206
  • Oct 16, 2005
  • #206
doing it that way just makes it so that it goes into the crank case, because it all drains down to it
menasci
640
Chandler, AZ
Oct 17, 2005
#207
  • Oct 17, 2005
  • #207
So either way is OK?
Is one way better or easier than the other?
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 17, 2005
#208
  • Oct 17, 2005
  • #208
Yes, either way is okay. I didn't know about the way ponysarepretty did it, but his way seems a lot easier as you can use the tube to suck it straight out of the can whereas my way you have to use the straw. Neither way is better, they go to the same place.
ponysarepretty
578
#209
  • Oct 17, 2005
  • #209
I think they changed the PCV location, however I couldn't pull out the red line and didn't want to use too much force, so I pulled the one under the intake hose. However it is fairly wierd trying to get the PCV valve out from under the mess of wires and the big hose.
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 17, 2005
#210
  • Oct 17, 2005
  • #210
You don't pull the actual red line, but the black hose connecting the plenum to the 2 red lines.
menasci
640
Chandler, AZ
Oct 17, 2005
#211
  • Oct 17, 2005
  • #211
I just installed new Spark Plugs 2 months ago.
This will be the first time I've ever used Seafoam.
Will this foul up my new plugs?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 17, 2005
#212
  • Oct 17, 2005
  • #212
This thread makes the baby jeebus cry...
ponysarepretty
578
#213
  • Oct 17, 2005
  • #213
Then it looks like baby jeebus will be crying well into the future...
Teh seafoam will never die
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 17, 2005
#214
  • Oct 17, 2005
  • #214
I agree. Bow down to teh seafoam
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 17, 2005
#215
  • Oct 17, 2005
  • #215
Your momma makes baby jeebus cry
Okay, sorry...that was lame.
DogVomit
192
Tampa, FL
Oct 17, 2005
#216
  • Oct 17, 2005
  • #216
Simplest HP boost. Pour a ful pound bag of sugar in your tank and see the results!
Good luck on your Sea Foam experiments. If it doesn't add 20 HP, It's not going into my motor.
Drive well!
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 17, 2005
#217
  • Oct 17, 2005
  • #217
Drive well!
Do you use that B12 CHEMTOOL stuff or something?
menasci
640
Chandler, AZ
Oct 18, 2005
#218
  • Oct 18, 2005
  • #218
Well I did it.
I used an empty water bottle and some small tubing for fish tanks.
I sucked about 1/3 of the can into the upper intake, shut off the car, and waited just over 5 minutes.
Then I started that car, and revved it around 3k - 4k RPMs.
Lots of white smoke for about 10 - 15 seconds and that was it.
Very easy.
The smoke show was OK.
Unfortunatly, I had to watch it from inside the car as I revved, so I could not see the full effect.
I'm not sure yet if it made a difference yet, but I'm sure it was good to clean whatever carbon deposits there were.
Next I will pour some into the oil, and then the gas tank.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 18, 2005
#219
  • Oct 18, 2005
  • #219
That's cool I do not have a problem with SeaFoam, I use it and I like it.
It is just that there seems to be so much confusion and misinformation in this thread...
Use it three ways, simple as that:
-in gas (one can to a tank of gas)
-in crankcase (half a can, dump it in where the oil goes, change oil about 100 mile later)
-in intake (suck half a can in the vacuum port or pcv port, shut off engine, start back up ten minutes later)
That's it
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Oct 18, 2005
#220
  • Oct 18, 2005
  • #220
That's it
Some people, like myself, don't know where the PCV valve or any vacuum lines are leading to the intake. Not so simple in that case.
  • 9
  • 10
  • 11
  • 12
  • 13
  • 42
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Eastern North Carolina Autocross Events!
  • Warhorse Racing
  • Feb 23, 2026
  • Regional Forums and Event Information
Regional Forums and Event Information Feb 23, 2026
Warhorse Racing
  • Locked
93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
