Seam sealer around shock towers
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
I removed my spring, upper control arm, shock,etc... and was grinding away all of the gunk on and around the shock tower when out came a long strip of what looks like a beige seam sealer on the sides of the shock tower. This is on the inside of the tower, not the engine side. Has anyone encountered this before? What do I replace it with? It looks near impossible to use a caulking tube of sealer with the fenders on.
I didnt notice it on my 70 when I cleaned out the towers, but you could probably use 3M seam sealer wadded on the end of a 1 1/2 inch putty knife to work it back into the seam, then use a rubber glove and pack/smooth it back into the seam with your finger. :shrug: If you dropped the whole fron suspension out of the car without removing the fender, I'm sure you'll be able to get the seam sealer worked back in!!! :hail2:
Good idea. I guess a local paint store would have sealer in a can. :shrug: I learned some tricks dropping that suspension that'll save time if you ever need to do it. I learned the hard way so there's no need for anybody else to. :D
Yeah, whichever is cheaper I guess. I was surprised there was a small gap there but understand the need to keep water out to prevent rust. If I was a welder, I would probably zap it shut. THX for the ideas!
