Seam Welding
  • Thread starter Thread starter 68FBJJZ109
  • Start date Start date Apr 18, 2006
68FBJJZ109
357
Easton, PA
Apr 18, 2006
  • Apr 18, 2006
I am building up a 68 FB, and want to stiffing and reinforce it as much as posible, I have the Dr Gas shock tower kit, and TCP Sub Frames, and plan on getting at least a 6 or 8 point cage, but i know you can seam weld everything as well to reinforce the factory tack welds. I did a search on the forum with little luck, are there only certain areas you need to do? what specifica ares shold be seam welded, I can make a guess of where i think they need to go just wondering what other people have done,. Thanks
351w_swap
263
  • Apr 18, 2006
If your going to do it, why not do it everywhere, its not like it will become weaker if you put on an extra seam? If it's worth doing, it's worth doing right!
68FBJJZ109
357
Easton, PA
Apr 18, 2006
  • Apr 18, 2006
Ok, how much weight do you thin thats adds? not like its a big deal the weight is low on the car, and i will more twice the hp i needs, I am just curious.
Jester67
908
TN
Apr 18, 2006
  • Apr 18, 2006
Spot welded lap joints are VERY strong if they are in good condition so I do not see structural benefit to seal welding. On the other hand if done correctly on a clean dry lap it will eliminate the corrosion that can happen to those joints this would be a replacement for seal sealer but would be a lot of work and would take a long time. I would concentrate on locations that will be exposed to the weather first. It is my opinion that it would be better to add materials where they would do the most good as mentioned above.
bnickel
5,640
lubbock, texas
Apr 18, 2006
  • Apr 18, 2006
i plan on going with tank armor as well but i'm gonna go a step further than you did and build an angle iron frame for the top side as well so that the tank and the tank armor actually sits down in the angle iron frame and then with the steel strips underneath as well. should be strong enough that the car will collapse around the gas tank without crushing it
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
Torque box reinforcement with cage?
  • DeathProof88
  • Jan 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
DeathProof88
Progress Thread Roll cage and LS swap?????
  • 78mIIman
  • Dec 30, 2024
1974 - 1978 Mustang II Talk & Tech Mar 30, 2025
greenflash79
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
