  • SN95 4.6L Mustang Tech
Secret Incantations for GT front brakes ?
  • Thread starter Thread starter TripleBlk
  • Start date Start date Aug 28, 2008
First Prev 2 of 2
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Jan 3, 2010
#21
  • Jan 3, 2010
  • #21
Unbolt the MC from the booster and see if that frees them up. If it does, the brake booster rod is adjusted out too far and causing the brakes to drag. Turn it i n slightly
Cobra123089
94
Broomfield CO/ Laramie WY
Jan 3, 2010
#22
  • Jan 3, 2010
  • #22
We dont have boosters...
flymikemc
34
nashville
Jan 3, 2010
#23
  • Jan 3, 2010
  • #23
Well I bit the bullet and got two re manufactured units put them on and wow what a difference. It went from being hard to turn the wheels with two hands to being able to spin the wheel one full revolution with a pinkie finger. If I push it with my foot it went 6.5 revs with out stopping. I was driving around with my brakes on for a long time. I wish I had done this years ago.
Key words for searchers; brake problems, calipers sticks, brakes won't release, brakes on all the time, my car sucks , 5 lug conversion. If you can think of anymore please add them so someone won't have to deal with this in the future.
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Jan 3, 2010
#24
  • Jan 3, 2010
  • #24
I know this.
I was answering post #20
Mileshigh
25
Raleigh
Jan 4, 2010
#25
  • Jan 4, 2010
  • #25
Brake Cylinder
I doubt the brake pistons are not steel as im sure the engineers at ford would use nothing less on a part under this kind of stress. Polymers under such load suffer from creep and stress relaxation which = failure. Although it is highly likely that the piston has a polymer coating to prevent metal on metal binding....thats just my two cents from a polymer engineer
flymikemc
34
nashville
Jan 4, 2010
#26
  • Jan 4, 2010
  • #26
The guy at pepboys asked if I had the "phenolic or steel" they were different prices so there is a difference.
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Jan 4, 2010
#27
  • Jan 4, 2010
  • #27
The ones i looked at used a phenolic piston.
Seems a common prob for the 99-04 calipers to stick. I've seen it a lot on the boards. None of the other Mustang calipers are so prone to it.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 4, 2010
#28
  • Jan 4, 2010
  • #28
youve been misinformed. Ford tends to use phenolic caliper pistons on the higher performance applications. for the p71's the police interceptors use phenolic vs steel for civilian models.
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Jan 4, 2010
#29
  • Jan 4, 2010
  • #29
Only because the Phenolic pistons transfer less heat to the fluid keeping it cooler and allowing less fade over repeated use. Good if you are driving a cop car hard which sees regular maintainence. In terms of durability though, he's right. Phenolic pistons tend to suffer more from sticking in the bore than their steel counterparts.
I'm pretty sure that the 99-04 GT's come with a phenolic piston. I'm going off memory from when i had a few sets before selling them all. One of the downsides is they are more prone to seizing...which is commonly seen. The other SN95 calipers use steel pistons.
Unsure if there is a steel version of the GT PBR out there, but that would be the way to go if you stick with the 10.8" brakes.
I
IvyMike
26
Huntington Beach, CA
Jan 4, 2010
#30
  • Jan 4, 2010
  • #30
Most of the "secret incantations" I use while doing brakes involve a lot of 4 letter words at high volume while throwing wrenches and hammers.
Works every time
flymikemc
34
nashville
Jan 4, 2010
#31
  • Jan 4, 2010
  • #31
I had a feeling I picked the wrong ones. I got the Phenolic ones cuz I wanted to save a buck and thought they would transfer less heat. How long you figure I can get out of them before doing it again?
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
Jan 5, 2010
#32
  • Jan 5, 2010
  • #32
The phenolics do transfer less heat.
I wouldn't sweat it. Plenty of '99's still driving on oriignal calipers out there
usafveteran
9
West Chester, Ohio
May 13, 2019
#33
  • May 13, 2019
  • #33
I know this is an old post but it's in the same vein. I replaced the calipers on my 2004 GT with new ones (Autozone), the right wheel seems to turn free but the left side takes two hands...…..bad caliper or wheel bearing????
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,047
224
Massachusetts
May 13, 2019
#34
  • May 13, 2019
  • #34
Unfortunately only way to tell is to pull the wheel off, unbolt the caliper and lift it off the rotor and see if the hub is tight.
My guess is it's the caliper
usafveteran
9
West Chester, Ohio
May 13, 2019
#35
  • May 13, 2019
  • #35
Appreciate the response. I'll give it a shot!!
usafveteran
9
West Chester, Ohio
May 13, 2019
#36
  • May 13, 2019
  • #36
It was the caliper!
Reactions: Mustang5L5
usafveteran
9
West Chester, Ohio
May 13, 2019
#37
  • May 13, 2019
  • #37
Don't know if I wrote this in the right place but it WAS the caliper!! Thanks.
First Prev 2 of 2
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
C
Scraping sound while turning?
  • crazyone64
  • Aug 13, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2024
crazyone64
C
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
