mootang said:
does anyone have an opinion on the cams I have listed other than the modular guy?
Why not just search for combos using AFR 165's, rpmII, and the cams you've put on your short list?
The cam needs to match up well to the heads & intake for the best performance. The other supporting stuff like tb, maf, headers and the like are not as critical as the h/c/i when trying to compare your ideas to what results others have achieved with similar combos.
I think the ProM 80mm maf is one of those parts that is well worth the money and would recommend it to you over the C&L.
You don't give any goals or expectations for your combo but with those heads and intake you have some real potential for a strong mid to high end power range that can exceed the 300rwhp benchmark easily.
If the above is along the lines of your expectations then you might want to think about a few of the following things:
The 24lb inj's will not have a lot of breathing room at stock fuel pressure. If you raise the fuel pressure then things will not be quite as close to the limit. If you have any thoughts about doing the spray thing then the 24's very well could get you into trouble.
A cam large enough to work well with those parts may cause you to have some drivability issues. You did not say if this is your daily driver.
You may need to have a chip done or get into self tuning to take care of those issues.
If by chance you don't have to deal with drivability issues a custom tune will yield more power than what you can achieve by mechanical methods.
Either way, IMHO, a custom tune is an item that is needed to get the most from a combo with that kind of potential.
Later
Grady
