Selecting gears with engine off
  • Thread starter Thread starter Mach1 Ian
  • Start date Start date Dec 7, 2008
Mach1 Ian
37
United Kingdom
Dec 7, 2008
  • Dec 7, 2008
70 Mach1 FMX Box
Eventually got round to making a start on changing the heater matrix, still haven't got it after ordering it 3 weeks ago, some parts out of stock
When i came to put in 1st gear( auto box )so i could get at a awkward screw the lever wouldn't go down past neutral unless i started the engine and i am sure i have never had this problem before, i know that i have a problem with neutral start switch as it wont start in neutral unless i slightly push the selector lever up wards. I have tried adjusting the switch as i have done before but it didn't make any difference this time. Is it my memory thats failing or does the start switch want replacing or is it some thing else?
Cheers
Ian
__________________
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 8, 2008
  • Dec 8, 2008
Mach1 Ian said:
70 Mach1 FMX Box
Cheers
Ian
__________________
Are you sure you had to start the engine, or just turn the key to the "run" position? If I remember correctly, my FMX wouldn't go past neutral unless the igniton was set to the run position, but the engine didn't actually need to be running.
I believe it's an anti-theft thing.
Mach1 Ian
37
United Kingdom
Dec 8, 2008
  • Dec 8, 2008
You are right, i started the engine first of all then i tried it with igntion in the start position and in each case that was the only way i could get it to go past neutral. If you are right in what you are saying this is the first time i have noticed it wont go past neutral in the 4 yrs i have owned, i must be getting old and losing my memory
Thanks very much for your help.
Ian
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
