sensor question
noslow1986
274
oswego Il
would a act or map sensor cause a hesitation. it feels like a rev limiteded soon as i hit 4500 rpms or more it feels like i have a rev limiter. now i have a reman auto computer in 5 speed car switch to mass air and a 91 gt motor.im still using the same 86 map sensor on the firewall, should i switch to a 91 map sensor? i unplug the vacuum line to the map sensor and makes no difference doesnt die or nothing. what about a act sensor. what gives i already unpluged the msd. how about fuel pumpnot pump enough fuel at high rpms. im lost
The Map sensor becomes a Baro sensor in mass air cars. It is vented to the open air & not connected to the intake manifold.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
