  • SN95 4.6L Mustang Tech
serpentine belt replacement
  • Thread starter Thread starter Stanged78
  • Start date Start date May 13, 2006
First Prev 2 of 2
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 2, 2007
#21
  • Mar 2, 2007
  • #21
so 8 and 9 are the idler pulleys? I think i have a squeky one when it's cold
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 2, 2007
#22
  • Mar 2, 2007
  • #22
Mustang5L5 said:
Damn i'm too late, i really wanted to post this.
Oh well it will help someone out if they do a search later.
Not to pee on your parade, but shouldn't your belt routing diagram be located on a sticker on your front suport, right near your radiator. That's where the one on my Cougar is......even though I don't use that belt routing set up anymore.
J
jadie24k
#23
  • Mar 28, 2007
  • #23
Ok, stupid question, but I'm completely new to Mustangs, and I need to change my belt. Your diagram has made it very clear the order in which to route the belt, but I have a procharger installed - how does this affect the routing? I'm sure I could just look and see, but I just wanted to make sure. Also, where can I get the "gator" belt, and what is the part number? Is it any different if I am running a procharger? Oh, and where is the belt tensioner located on that diagram? Is it one of the numbered items? Thanks!
2000GTnoExtras
990
Rocklin
Mar 28, 2007
#24
  • Mar 28, 2007
  • #24
Slightly off topic, but I recently replaced my serp belt for the second time since I've owned the car, now at about 72K and my A/C works like a dream. Yes living in Northern California last week required the A/C.
Cheers! -I found the part number searching for my vehicle on kragen.com / autozone.com / napaonline.com all showed the same part number. +1 for the goodyear gatorback belt.
BannonJr
215
St.Lazare Quebec
May 7, 2007
#25
  • May 7, 2007
  • #25
Hey! Its May 7th 2007...I used the search function...and taddaam! It saved the day again!!!! Woohoo!
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
May 7, 2007
#26
  • May 7, 2007
  • #26
5L5 is going to pop a boner when he sees this!!!
Superhereaux
chicks make me feel inadequate
538
South Texas
May 7, 2007
#27
  • May 7, 2007
  • #27
i was thinking the same thing
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
May 8, 2007
#28
  • May 8, 2007
  • #28
Hahaha, you guys are too funny.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 8, 2007
#29
  • May 8, 2007
  • #29
//jealous
R
Rccarfreak33
#30
  • Jun 22, 2007
  • #30
I've never changed a serpentine belt before and my bullitt needs to have its replaced, I'm assuming number 7 is the tensioner but i cant seem to see this square hole you are all talking about I only see the small bolt that holds it on?
W
WydOpn
39
Michigan
Jun 22, 2007
#31
  • Jun 22, 2007
  • #31
You might be looking at the bolt that holds the tension arm to the FEAD (shown in the diagram between pulleys 6 and 7). The square hole used to relieve the tension is at the other end of the arm...
R
Rccarfreak33
#32
  • Jun 22, 2007
  • #32
yea thanks i found it it was a lot more obvious then i thought haha
RandyStinchcomb
1,159
Randallstown, Md
Jun 22, 2007
#33
  • Jun 22, 2007
  • #33
just an FYI but that pic is for 1999 up to 2004, as 1998 back do NOT have #9 which is a ribbed idler
First Prev 2 of 2
Belt Tensioner Question...
  • robw13
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2025
gkomo
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
