serpentine conversion....worth it?
  • Thread starter Thread starter baker2956
  • Start date Start date Apr 9, 2004
baker2956
48
NY
Apr 9, 2004
  • Apr 9, 2004
Hey guys. Ive got a 67 coupe w/ a 302. I was pondering the idea to convert the little v-belt I got to the serpentine. Is it worth it or should I just stick w/ the v?
R
Ronstang
1,294
Houston Texas
Apr 9, 2004
  • Apr 9, 2004
Let me put it this way....the only cars I will ever use v belts on are my 57 T-Bird and my Shelby, for obvious reasons.
baker2956
48
NY
Apr 9, 2004
  • Apr 9, 2004
do you happen to know a cheaper way to do other than Marche' s kit($540)?
66P51GT
721
Cerritos, CA
Apr 9, 2004
  • Apr 9, 2004
Grab the brackets from a junked Explorer or Mustang. I'd purchase a new reverse rotation water pump and belt. If you don't run A/C, you may need an idler pulley. The lower crank pulley will probably be a 4-bolt pattern. Classics use 3-bolt. You can either puchase a custom pulley or a 28oz dampener that supports a 4 bolt.
brianj5600
1,964
Middle TN
Apr 9, 2004
  • Apr 9, 2004
To me it is not worth it. I don't ever have V-belt problems. If it ain't broke, don't fix it. Unless you have more money than you know what to do with.
Swede958
712
Austin, TX
Apr 9, 2004
  • Apr 9, 2004
Got the brackets from a junkyard engine for 60$, new waterpump (higher flow) for 100$, compressor to fit the brackets for 230$, P/S pump for 35$, hoses for 70$ (Custom).
I like it, just make sure the pulleys line up right- ate a belt that way once.
The Swede
allcarfan
The Answer Man
2,458
North Atlanta
Apr 9, 2004
  • Apr 9, 2004
Marches kit is $540? It was $360 when i looked the other day.
You can find a fox chassis parts car and just use the parts from it...idler assembly, ALT bracket, etc etc and swap it to yours. However, I believe you will have to drill out the holes on the alternator bracket because the accessory holes on early model heads are smaller. You will...even if you DO run AC, need an idler/tensioner pulley. A reverse rotation water pump was used on 94-95 mustangs if I am not mistaken.
Shane
68_stanger
131
Petoskey, MI
Apr 9, 2004
  • Apr 9, 2004
I did the serpintine conversion, I canibalized an old ford van for mine... everything bolted up fine, needed the reverse rotations waterpump and a spacer for the pully on it. I had to modify the D.S. power steering bracket as it was in the way for the vaccum advance on the distributer.
R
Ronstang
1,294
Houston Texas
Apr 9, 2004
  • Apr 9, 2004
Like everyone has been saying, it is time for a trip to the jumkyard. I can't tell you how much neat stuff I find at the junkyard for very little $$$ that with a little cleanup, slight modification, and a little imagination looks like something brand new on one of my projects. Serp belt setups are a dime a dozen in the boneyards now so go find one that looks nice to you....I like the 85-93 Mustang one but there are many variations and almost all of them will work.
I am involved with a lot of other people's projects so I always seem to collect everyone's cast off parts and this is how I ended up with the serpentine system on my current project. One man's junk is another's treasure.
baker2956
48
NY
Apr 9, 2004
#10
  • Apr 9, 2004
  • #10
looks like im off to scout the local yards this weekend
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
Hello
  • TomcatPC
  • Jan 15, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 18, 2026
TomcatPC
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
