SERVICE ENGINE LIGHT W/STEEDA U.D'S
I'm gonna say it's a misfire code because you didn't torque the crank bolt down to specs, what kind of pulley's are they?
take care of this right now, I went through absolute hell for letting that light go, get under there and torque it properly, off the top of my head I can't think of the exact lbs to torque it to.
the torque spec for your car is as follows:torque to 116-121 lb-ft.
loosen bolt 1 full turn
torque to 37 lb-ft
tighten bolt an additional 90 degrees
This directly from the Steeda installation instructions.
Hope this helps
