While I'm at it, I was thinking of cleaning up the injectors but have no clue as to what to use to clean them up. Can I just use Isopropyl alcohol? or is Ethanol better. I see no difference... Or soak them in that seafoam stuff?
Will put that seafoam in there once I close everything up. Is this better and more simple as it is pressurized through the injectors?
I thought I should take a Q-tip and clean out the MAF too.
Some waterweter in the coolant while all has been flushed out.
Nothing much but cleaning out the interior of the air box and tubing won't hurt.
Am I missing anything? Will just take advantage of the down time and do some extra stuff to it.
Plenum porting?
Maybe I should try porting my stock plenum... Can I do it with a dremel? What type/size grit balls would I need?
I have a write-up from http://www.standardabrasives.com/ at home, I'll take a look at it again as it's been a while.
Al
Plenum porting?
Al
