used a procedure from this site but the rocker arms seem awfully loose when the rocker in question is on the base circle. Is that normal ?
Heads are called pro comp from ebay. they seem to have sold a ton of them. however when I asked the seller he said they were his castings.Hi, It sounds like your Pushrod length may be on the low side. I just typed that when your text came in, lol! Yes, sounds like you’re a bit shy. Checking Springs are light, but can cave a Hydraulic lifter- yes. You need to run a Solid lifter on whatever you’re checking. I’d just installed AFR Heads, Screw in Studs, 6.700. TrickFlow’s, 6.700, Brodix, 6.500. What Heads are you running?
- John
Well the motor seems to hold compressed air for all cylindersRocky, One last thing. Whenever I get a set of Heads to put on a Customer’s Car- Brand new or used & “reconditioned” alike, I ALWAYS send them to a friends Automotive specific Engine Rebuilding Shop to verify they’re squared up, pull all the Springs to verify their PSI Spec’s are the same, ensure they run the Spring Cups under the Springs (As without they’ll eat into the Spacer(s) if installed & into the Heads). Check Guides, Check Valves & Seats & grinds, install Viton Seals, Pressure test, etc.
If on a strict budget, I recommend they at least, pressure test them.
As even well known Companies have assembly lines, many mistakes may occur.
Try this:
If you prop them up so the Chambers are up & level, add H20 to each chamber & see if any H20 leaks out, water molecules are larger than air molecules, i.e.; If Water leaks, they’re guaranteed to leak compressed air.
Last thing you need is to find a Compression leak due to a Calve/seat issue & have to pull a Head once you’re done.
I’ve come across some awful mistakes from brand new Heads, one set the Seats were Cracked, another had almost no Valve margin in their Grind- Valve edges would have melted with its first hard run, etc..
Shyster a friendly FYI. Trust NOTHING.
Good luck- John
Heads are already torqued downWell the motor seems to hold compressed air for all cylinders
John,So, you did a Compression test? What did you end up with for Cylinder PSI & differences between? Didn’t mean to spook you with getting Heads checked out prior to Install, it’s a personal preference that has proven to be helpful for me. Just keep in mind down the road.
The Castings on these Heads seem good, it’s normally the Valvetrain components that people have had issues with. Reviews read are a few years back, many I could see the people were incorrect regarding comments & things may have improved. They are made in China, but that’s not always bad, may be to keep costs down. Is it running Cups on the base of the Valve Springs? That’s an important one.
Can you precisely align the Rocker tips with both Valve Stems with Pushrods installed using the 1 PC Guideplates the Heads came with?
ISKY & a few other Mfg’s make independent Guideplates (one per Valve) for aligning Stem to Rocker’s lateral movement. They interlock & slide together for improved adjustments requiring greater control than a Single Guide-plate can accommodate.
Rocker Studs clamp them in place, same as single Guideplates, but allow independent Valve/Stem “tweaking” that single Plates cannot achieve.Cost is 25-40$.
They are often Welded together once adjusted, but it’s not mandatory..
Are you planning on Degreeing the Cam in? I’d Retarded the last TFS-1 Cam for a better midrange-Top end, it didn’t affect low RPM response much, Cam’s specs, events were right on. I ran a TFS2 Cam & Advanced it 2 Degrees, was a Customers DD, Car ran great.
Valve to Piston clearance was close with the 11R Heads (Basically a CNC ported TF T.Wedge 170cc Head), but shares the larger Valves yours have. Piston reliefs on 87’-93’ stock Forged Pistons are of no help,
Stage 1 vs. 2 difference was 23 RWHP, both Dyno’d, in comparison with near identical 331’s.. BOTH Stage 1 & 2 are GREAT Cams, Stage 2 is a bit lazy below 2,500- comes on hard @ 3K to 6,500, both will keep on pulling beyond, if you’re running 5/16”
OE Rod Bolts, I wouldn’t spin beyond 6,500 repeatedly for longevity. Looks like a 300RWHP build, APPROX , providing you port the Explorer lower & do the typical 70mm TB, 76mm MAF, LT’’s, Cobra upper, 24lb injectors, etc with a good Dynotune. Have lower Gears?
Do you have a 9 position lower Cam Gear?
Good luck! John
John,
I ran a length checker again with a solid lifter and checking springs and the mark is in the center of the valve stem with an allowable sweep pattern. Still coming out 6.350. please advise. but as stated the rocker arms still are pretty loose when on the base circles. I guess I will just go with the 6.350 push rods and see what happens. I tried 6.500 and the mark was too far towards the exhaust side. going to use the straub video and see what I come up wih. also my cam card gives a slightly different gross lift between intake and exhaust valves 0.499 and 0.510 so im going to split the difference. 0.505 my 7/16 studs give me 0.50 TPI
