setup (tfs)
stangjunkie
381
well now ive got my tfs tw heads, street intake, stage one cam on order along with lifters, crane 1.6 rockers, tfs pushrods, now im trying to do a weekend setup, I still need a new tb and maf, im thinking of switching to 24# injectors but what size tb and maf?? i really only know carbs so i dont know sizes for these... also while im putting all this on anyone think of anything i might as well do while im in here?? thanks again!!
also anyone know anything about holley tb?? i ask because i get 20% off a brand new one, (i can get the same deal on edelbrock stuff too...)
Nice setup : )
#24 and 75mm MAF, ProM , 70mm TB and EGR spacer. Worked well for me.
TFS EGR unit is made for better clearance around your Fuel Press reg.
Couple of extra threaded inserts, if you dont use the EGR.( rear of the sylinderheads)
Adj FPR (approx 40psi) and 14-18* of timing...
Dont know the Holley unit, Its ok, I guess. Good Luck : )
haha, this is the setup i'm installing in a month or two.
86gtstang- what pistons are you running? just curious
stangjunkie- you basically want the maf to be larger than the throttle body/egr so that it doesn't restrict your flow. I have a 65mm throttle body and egr, but with the new setup I'd rather have a 70 or 75.
stangjunkie said:
lol,hey you have my setup what suspension mods you runnin to get into 12's thats my goal
..Lol, same setup !
I run Steeda Alu. upper and adj billet lower control arms, dual airbags, FMS lowering coilsprings,koni rear shocks,Monroe front struts,STEEDA dragrace swaybar, welded torkboxes, and subframes. G60-15 (254/60-15) Racemaster DOT slicks.
No dragracesuspension, except adjusting the airbags because of bodyroll.
Im running my stock ones. Had them flycutted, home alone ,homemade flycutting tool...An oversiced chevy valve,2.07",glued on some grinding paper and a batteri drill. Clearance was tight without flycutting, only 0.75mm P/W clearance. If you can , just install new ones.:)
70mm TB and a 75mm MAF will suite you well with 24s. If the Holley TB is anything like the BBK or edelbrock, you will most likely get a chirping or blow off valve sound if you jump it just to let you know. Some people love it, some people hate it so I believe it was accufab TB which is pretty popular and didn't whistle or chirp. Just a thought
Kevin
