Correct me if I am wrong. The signal return wire only is grounded when the ke is "on"? With Key "off", should I be able to get an Ohm reading from say TPS ground back to the battery? And if it is only grounded with the Key "on", how can I check the quality of the ground of this SGNRTN wire since it will have return voltage on it with the key "on". I would like to check the SGNRTN wire to insure its integrity since so many sensors use this wire.
