  • SN95 4.6L Mustang Tech
Shaking after gear install
  • Thread starter Thread starter L33T MinGrey GT
  • Start date Start date Oct 8, 2004
L
L33T MinGrey GT
51
  • Oct 8, 2004
I had my gears installed a week ago exaclty, and I let them break in for about 250 miles. Gears are FMS 3.73's and they do not whine at all. The only problem is that going over 80-100 miles (not to say 120-130 like test driving them today) the car shakes like a little 2 cents whore. It almost shakes like if the tires were messed up, even though they are 2000-3000 miles new.
I realized that right off the shop, in 5th gear it will do it very mildly and if you let off the gas it will reduce it noticeably. Is this a ****ty install? or is it normal that with bigger gears ur car shakes a little bit more. I mean is not the end of the world but going from my 3.27's in high speed I really notice the shaking more (even though if Im not mistaken I had a little bit going over 100).
Any help will be appreciated.
TIA!
R
Rocketman
730
SoCal
Oct 8, 2004
  • Oct 8, 2004
Did you take the vibration Dampner off the differential "the dog bone"?
Also, try indexing your drive shaft one bolt hole.
blkhorse
345
Oct 8, 2004
  • Oct 8, 2004
it is possible that a wheel wieght fell off when they removed the tires
L
L33T MinGrey GT
51
  • Oct 8, 2004
Thx for your fast response guys. I checked on the weights and they are there, I might go by my friends shop for balancing and alignment anyways. Regarding the "dog bone" I do not know if they did this ( I was not the one that installed them), could you explain that to me, what is it exactly that way I'll go and check with the mechanic.
Thanks a lot.
R
Rocketman
730
SoCal
Oct 8, 2004
  • Oct 8, 2004
Here's some good info.
http://www.corral.net/forums/showthread.php?p=3857794&posted=1#post3857794
GOLDENPONY
1,503
LOVELAND, OHIO
Oct 8, 2004
  • Oct 8, 2004
Shaking after gear swap
What you are describing is fairly common (it happened to me too) after going to 3.73 gears or higher. I read about this scenario and that going to an aluminum driveshaft was the answer. I put in the al d/s and indeed the shake went away.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
