shaking shifter
tony laq
121
anybody ever get this? i notice it if my trac control goes on and the car is really looking to get traction, like in snow, the shifter arm shakes like mad. also, i live down a STEEP driveway and sometimes if i have to back up it and its wet ill get some wheel hop and a nasty little shake in the shifter...anyone else have this?
btw ive got an mgw if that helps.
thanks...tony
my MGW is pretty stiff. i mean it vibrates, but doesnt shake as bad as you're describing.
diagnosis:
check the 4 bolts that hold the tranny base to the tranny. they may have come loose.
possible busted tranny mount
Shifter is bolted directly to the trans, so anytime you get driveline shake, the shifter will shake.
If you rev your engine in nuetral, you'll notice the shifter pitches to the left.
Any driveline chatter will cause it to shake as well
thanks for the info guys...i dont get any stick movement at any other time ( other than shifting of course )its rock solid . im thinking it may not be a huge deal right now but the fact that it could be the whole tranny moving isnt good.
