Figured i'd clean up the "other" thread by just copy and pasting and continuing here
Here is the **** i found in the oil pickup
Remachined the throttle body surface since some jackwaggon jb-welded the egr spacer and throttle body on
Finished shortblock
Fabbed up a gt500 heat exchanger in place of the puny vortech one, especially having a mount bracket made for a much cleaner install
Here it is compared to the vortech exchanger
Here is how i had to modify the bracket to rotate the exchanger in place and make it clear on the car
Mounted on the car
Here are all the additional parts I got with the car
Fresh gauge panel
All new weather stripping
Interior and exterior felt trim
Run channel strips
Radiator
Sn95 brake setup
Taylor battery relocation box
Dash vents
Rivet gun
Door panels
Arm rest pads
Visors
And other misc parts
Finished shortblock
Mounted on the car
Fresh gauge panel
Run channel strips
Radiator
Sn95 brake setup
Dash vents
Rivet gun
Door panels
Arm rest pads
Visors
