65fastbackresto Active Member Apr 13, 2007 1,229 7 39 AR May 10, 2007 #1 May 10, 2007 #1 On my 65, the shock mounts in front of the rear end, not the back. Is this right?
302 coupe Founding Member Mar 2, 2000 1,952 3 36 Macon, Ga. May 10, 2007 #2 May 10, 2007 #2 yes. You should be able to tell just by looking under there, its quite obvious.
65fastbackresto Active Member Apr 13, 2007 1,229 7 39 AR May 10, 2007 #3 May 10, 2007 #3 Just trying to find out If mine are correct, I had the issue with Mustangs Unlimited, and I need to know if its my fault or not.
65fastbackresto Active Member Apr 13, 2007 1,229 7 39 AR May 10, 2007 #4 May 10, 2007 #4 I just figured it out. They sent me 2 mounts for the drivers side and none for the passenger side, which is the side I did first. Nevermind, I got it now.
