- Nov 27, 2005
- 22
- 0
- 0
I was coming home from work and my 95 Mustang GT shut off. First off I have a 393ci fuel injected,24lb inj., Trickflow 1 cam Mustang. I check the usual stuff-ignition, mass air, fuel pressure, harmonic balancer, distributor, moisture, proper voltage at ignition coil etc. I replaced the coil to no avail. Previously replaced ignition module, act sensor, rotor. I put a used a 255lph fuel pump but I still have 33psi fuel pressure showing from gauge with vaccum line attached. What would cause it to shut off and not crank up. I tried to list as much without being to lengthy so don't be afraid to ask something I might of checked.
