Sheetmetal valve covers
Iam looking for a set of fabricated sheetmetal valve covers that have baffles, will clear roller rockers AND will fit under a EFI intake without a spacer. Ive found afew different ones and I like the look of them but none state that they will fit under EFI intakes with no spacer. Any suggestions?
attachment.php
I have a set of trick flow fabbed covers. In my opinion, they would not fit without a spacer.
Also, they dont have baffles, but I suppose you could make your own.
Overall , these are the best fabbed VC i found. I have a 1" spacer.
Good luck with your search!
Thanks for the input, as I said before nice engine bay. Yea those valve covers look pretty sharp but like I said i really dont want a spacer. Last year I ran a 3/8" spacer on my performer intake and it ended up hitting the hood which I dont want to happen anymore. But if I have to run a small spacer maybe I could work at the hood abit because it would just hit one of the braces on the hood. By the way, how tall are those valve covers?
www.propan.net
look up valve covers under ford.
i work here and this stuff is GOOD.
3/4" rail, tig welded 100% inside and out, can get custom heights, filler bungs, vent, oiler systems etc.
can get pretty much what you need, and this stuff is well worth the price
