- Feb 7, 2008
- 12
- 0
- 0
hey im looking for websites or links to places where to get the a gt500 wing.....Ive seen where they come pre painted and bolt on....but cant seem to find any stores anywhere online....ive seeen ebay stores in the past but just did a search and got 0 result match please help......post links please so i can shop and buy one...like i said i want one painted.........seems like i saw a store that sells take off gt,gt 500, and v6 lip spoilers....but cant find that either....all help is appreciated.......please post all links for me.........
why i am at it need links for honeycomb tail black out....and chin spoilers.......but really want a rear spoiler...help help help.......thank you guys
)! There are two screws in each front wheelwell that need to be removed and replaced through the spoiler. The screw tabs make it very easy to snap it in place for test fitting purposes! Once you are happy with the placement of the spoiler, remove it from the car and peel back a few inches of the adhesive tape backing in each direction from the center. Make sure it sticks up over the top of the spoiler as this is how you will pull it out from behind the spoiler on final install. This is the part where the directions say to remove both front wheels. RUBBISH! I found it much easier to turn the wheels full lock in one direction, remove one screw on each side, then turn full lock the other direction and take out the remaining two screws. This can be done in a matter of a minute(provided you have a screw driver that is only a few inches long to clear the wheelwell and the tire)...how long will it take to raise up the front and remove both wheels????? Lift the spoiler up and align one of the holes with the fender and replace one of the screws. Go to the other side of the car and lift up the spoiler and align/replace one of the screws there. Now go to the front of the car and line up the spoiler to the lower grill(it should butt right up against it covering the entire painted section of your bumper)and firmly press it. Now once that is done, take one of the pieces of tape backing and slowly peel it out from behind the spoiler making sure it stays up against the lower grill(mine stayed put and needed no further alignment after the center was tacked down). Press down firmly on that spoiler half. Now onto the other side removing the backing tape and repeat pressing firmly once it is fully removed. Replace the remaining two screws. Now stand back and enjoy your new front end! I know this was long winded, but even by yourself, you could have it installed in about the same time it took to read this
