Shift Kit
  • Thread starter Thread starter z9_87
  • Start date Start date May 13, 2005
z9_87
332
Urbana, IL
May 13, 2005
  • May 13, 2005
I want to ut a shift kit in my aod. I have never played with transmissions before. How hard is it, any special tools, about how long will it take? Would you advise against it and recommend someone else doing it? I'm fairly competant with engines to i feel like I can tackle this, but I have a friend who says the ford aods are a PITA to modify.
Thoughts?
sgarlic
3,085
May 13, 2005
  • May 13, 2005
I did one on a mopar tranny.. and I have the kit for my aod but going out of town for a couple weeks so can't install it for a little while.
It's pretty easy if you follow the instructions. You just drop the tranny pan, remove the filter, remove the valve body, turn it upside down, do the shift kit mods, then put it back together. Some people say to plan on nearly a full day of work to do it.. we did it in about an hour and a half.. if you have at least some wrench turning ability, and can follow instructions, you'll be fine.
Obviously, if problems arise (drilling in the wrong spot, losing check balls, etc) it'll take longer.
M
macx
228
SE Missouri near Cape Girardeau
May 13, 2005
  • May 13, 2005
I recently put in a Baumann kit in just a couple hours.
Very good, complete instructions & pictures.
For info on making mild to wild mods on your AOD, check out www.lincolnsonline.com their tech section, transmissions, on HD AOD internals. There are several things you can do without getting into the trans that can help it live and perform.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
How Many Runs For A Built C-4
  • 93gtmustang
  • Apr 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
revhead347
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
