Hey guys, I figure this place moves faster than the 2.3 forums...
I ordered an MGW and am getting ready to install it, after reading some threads on here I decided to remove the console. I don't have a ratcheting box end or combo to get to the bolts under the radio. So far the console removal is going well, except for the screws in the glove box. I've already taken the glove box out and one of the screws next to the fuel door/hatch release. I can't get the second screw out and I can tell if I keep turning the screwdriver, it's going to strip. Does anyone have recommendations on removing the screw or is there a way to work around it? I have to believe the shifter install will be a breeze after this PITA....
Thanks in advance for the help.
EDIT: I've gotten the plastic under the steering wheel off to expose the 2 screws holding on the console on the other side. These are just as hard to remove as the one on the right side, I'm using the same screwdriver as I did for the screw that I was able to take out. WTF! Did someone overtighten these in the past and that's why I'm having such a hard time?
