Shifter Question's
  • Thread starter Thread starter MLee23
  • Start date Start date Mar 11, 2008
MLee23
34
Mar 11, 2008
  • Mar 11, 2008
Hi all. I got a few questions about my 90' GT Shifter...I am installing a Tri-ax shifter on my T-5 Tranny, and I noticed that all 4 bolts are gone from the Shifter trim ring/boot. Does anyone know what size these 4 bolts are? View attachment 327128
Also, this is an 05-08 mustang shifter knob. I strongly approve of it Would this fit the T-5 Tri-ax shifter?
Thanks!!!
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 11, 2008
  • Mar 11, 2008
my bolts where gone to and i used self taping screws and it worked perfectly. and as far as the knob you can always make it work if its to big use tefflon tape if its to small stip it on. i know this is horrible advice and they do make shim kits fot these applications. hold on i will find some
EDIT: steedas website list knobs ranging from 79-04 and 05+ so i doubt it will work properly
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Mar 11, 2008
  • Mar 11, 2008
here is an alternative though
http://www.steeda.com/products/ford_racing_shift_knobs.php
MLee23
34
Mar 11, 2008
  • Mar 11, 2008
Yeah, I figured that for the shifter knob. I might just go with the stock knob for now.
Fett
766
  • Mar 11, 2008
Yes, that knob will fit on a Tri-Ax shifter...that is what I have. You will need to cut off the bottom collar though, but you won't notice it once you cut it off.
However, as comfortable as those knobs are....the top part tends to pop off. Mine popped off a few times, even after super glueing it back in place, it finally popped off for good.
MLee23
34
Mar 11, 2008
  • Mar 11, 2008
I got the tri-ax from 5.0 resto.com, and it came with a Bullitt shifter, so I could use that too. It just seems a bit too "old school" for me. I have a 97' cobra also, and I love the OE shifter on that too. Too many options!!!
MLee23
34
Mar 12, 2008
  • Mar 12, 2008
anyone know the exact size of the trim bolts?
Saleen0679
876
24
49
Yakima, WA
Mar 12, 2008
  • Mar 12, 2008
M6 x 1.0 x 22mm
L
lineumup88
23
hampton va
Mar 12, 2008
  • Mar 12, 2008
they are the same thread as the fender bolts and they are an 8 mm head
MLee23
34
Mar 13, 2008
#10
  • Mar 13, 2008
  • #10
Thanks guys...You think I could grab 4 of em at my local ford dealer?
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Mar 13, 2008
#11
  • Mar 13, 2008
  • #11
Sure...if you want to pay $11/each!
MLee23
34
Mar 13, 2008
#12
  • Mar 13, 2008
  • #12
hehe, I'd prefer not to Would Autozone or someone like that have them?
Saleen0679
876
24
49
Yakima, WA
Mar 14, 2008
#13
  • Mar 14, 2008
  • #13
Not sure what variety Autozone carries. Any place that carries small metric bolts would work. There's nothing special about the bolts. To be specific they are flange head, 9.8 grade bolts but any correct size bolt should work. They're only holding down a trim plate.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Tires
  • 65er
  • Dec 18, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 9, 2026
Realmongo
