shifter vibration at high speeds and grinds while going into reverse.
Hi, I have 2001 GT just put a new clutch in it but grinds going into reverse, also transmission clunks when shifting but not at high RPM. When I'm doing about 90-95 mph the shifter starts vibrating intensely but if i put it into neutral the vibration is still there. Could it be U-Joints or drive shaft? And what could the grinding be? Any help would be appreciated.
Did it grind before clutch replacement? How many miles on it? A good place to start with the clunk and vibration would be UJoints(driveshaft) or motor/transmission mounts.
Hopefully the OP didn't damage the tranny driving that way. When I do a clutch I replace the nylon quadrant with the aluminum one along with an Ford OEM Cable and firewall adjuster. You need to ascertain the clutch is properly adjusted before further trouble shooting.
Reactions: stormsedge
