shifting troubles
  • Thread starter Thread starter 93GTosu
  • Start date Start date Aug 2, 2006
93GTosu
183
  • Aug 2, 2006
maybe you guys can help...
when i'm at the track there is no possible way for me to make the 1-2 shift at anything above ~4k-4500ish rpms (stock tach). It simply will not go in no matter what. Not power shifting or anything. No grinding noises or anything it just doesnt go....even if the clutch is on the floor its the same. i swapped the plastic clutch quad for a ford racing one and its the same.
relevant mods could be:
93gt basically stock motor
3.73s
t5
pro5.0 shifter
ford racing single hook clutch quad + cable
this really sucks cause i have to remember to shift before 4000rpms or i end up fighting with the damn thing till it drops to where i can get it in.
I havent noticed it on the street....probably cause i dont take 1st up that high.
thanks guys
EDIT: oooooh btw i learned to drive 5spd on this car....i did alot of stalling out and riding the clutch till i got the hang of it (a day) but didnt really grind any gears....its also ONLY the 1-2 shift above 4K
Redeemedsoul
70
  • Aug 2, 2006
gear synchro? ... only thing i can think of
bullitstang1313
713
Indianapolis / Columbus, Indiana
Aug 2, 2006
  • Aug 2, 2006
I'd have to agree with Redeemedsoul on it being the synchro, just wait until you get it with 2nd to 3rd shift and you end up punching your radio!
D
DeVus1
400
P-Town, Va.
Aug 2, 2006
  • Aug 2, 2006
Have you double checked the bump stops on the shifter handle?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 2, 2006
  • Aug 2, 2006
I had a similar problem when I cracked my first t-5 housing... check your fluid and for leaks
foxbody88stang
21
COLUMBUS,OH
Aug 2, 2006
  • Aug 2, 2006
If your in columbus i know a guy that will rebuild T5's reasonably. Sounds like synchros.Good luck
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 2, 2006
  • Aug 2, 2006
if the tranny is just simply not going in, if there isnt any grinding at all. Look at your shifter adjustments. A bad syncro will grind, you should be able to tell fairly easy if its in the tranny or the shifter..
93GTosu
183
  • Aug 2, 2006
yeah, who is he? i might need him now or eventually....
but it goes in smooth on the street and anything below... oh lets say 4Kish cause im not 100% sure...i'll double check the stops just to make sure but would the stops affect shifting at 5K vs. 4K???
i suppose i shoulda changed the fluid when i had the stock shifter off maybe? I guess i could do that now also, what should i put in it? how much?
thanks guys
D
Daggar
3,902
  • Aug 2, 2006
A clutch that is not fully disengaging can cause the symptoms you describe as well.
stangjunkie
381
#10
  • Aug 2, 2006
  • #10
no i just went through this just 2 weeks ago. it feels like you hit a wall when your shifting. pull down and it stops. then rpm's go down and it catches why?? your cable is bad clutch is only partially enguaged, then it essentially rev matches. i promise you it is your clutch cable get a bbk adjustable.
93GTosu
183
#11
  • Aug 2, 2006
  • #11
well i just put a brand new Ford Racing single hook quad and the included adj. cable on it a few weeks ago to see if that might fix it. It didnt. The plastic clutch quad was in pretty good shape, no teeth missing or anything. The clutch pedal did feel 10x better with the new quad but that coulda just been my head telling me "i just put a new part on so it must feel better." we adjusted it so that it grabs about halfway down or so...where ever the instructions told me (a webpage someone reffered). So how can the stock cable/quad and the new abj. cable/quad. both give me the same problem?? it does feel like hitting a wall....almost like i've got it in and then i give it gas but it doesnt go anywhere....
so Dagg could my clutch have a problem? i mean i did learn to drive 5spd on it and havent replaced it, i dont know what the previous owner did if he upgraded it or not. Or would it be more of a cable/quad problem like s.j. was saying??
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
