shimmy at 60 MPH
sdz
10
Sioux Falls, SD
I'm looking for advice from those experienced with a problem like this.
At 60 MPH I am getting a slight shimmy. I just bought the car this weekend, so I'm sure it could be a lot of things. I put a new set of tires on today (balanced of course). I also replaced all of the front wheel bearings (inners and outers).
I'm not familiar enough with these cars yet to know what are common causes.
It does it even if coasting at 60 MPH.
Driveshaft?
Most likely the driveshaft. Check the U-Joints to see if theres a lot of play in them, make sure the bolts are tight on the differential yolk. Has the driveshaft been removed? Maybe it was installed oppositely, you could try to rotate the driveshaft 180 degrees.
The u-joints look good. I will check the bolts and try rotating the driveshaft.
try jacking the rear of the car up and test in your drive way, do it with the wheel on and the wheels off, obviously if the shimny is still there with the wheels off thats not the problem, then try indexing the d/s maybe its just not lined up in the right holes. If that doesnt fix it pop it offf and get thi Hi speed balanced. If that doesnt fix it then you know your down to you clutch and flywheel.
I put the car up on the lift, and ran it in first gear. I could see the movement side to side in the driveshaft. So I would guess the issue is in that area. I will probably just pick up an aluminum drive shaft and see if it improves things.
The bolts in the rear end look fine.
So I suppose it could be the tranny or rear end too?
