shock mounts
  • Thread starter Thread starter HDTony
  • Start date Start date Jun 10, 2011
HDTony
134
Plainfield IL
Jun 10, 2011
  • Jun 10, 2011
Just got my 9" back from strange engineering, shortened and new axles. they do beautiful work by the way. what I need now though is, the bottom plates to mount the rear end in the new leaf springs, and Ubolts to fit this rear end.
anyone got a link to get some that will fit?
Fstbk
215
  • Jun 10, 2011
I would just sort through the CJpony website.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 11, 2011
  • Jun 11, 2011
U bolts can be scored at your local NAPA. CJ's did not carry the diameter that I needed.
If you are also wanting to add a good traction bar, a few include (and have attached) their version of the bottom plate. Caltracs and Slide-a-links come to mind.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 11, 2011
  • Jun 11, 2011
If your housing has the necked tubes, the 65-66 U bolts and plates will do. If you have the straight tubes, 67-70. If you have something non-stock, what diameter are the tubes?
hipo_p51
199
  • Jun 11, 2011
Cobra Automotive Shelby Mustang brakes & suspensions
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
