Shopping for heads, intake, and cam - need help
I think the Trick Flow package from Summit is a great deal, just don't go with the stage 1 cam. You can piece together a combo, just depends on how much you want to spend. Edelbrock, Trick Flow and AFR all produce really good heads. There is a sticky up top with many combos listed...check it out.
Jake
GTJake said:
There's a lot better cams out there than the stage one though. My suggestion is FTI or a comp xe grind.
Jake
I suppose if I was start my engine again I would have gone with a custom grind. If I go with a custom grind next year and I don't see any improvements or just slight improvements I'll really be kicking myself in the a$$ !!
